Help on connection
dahedgepeth
I am using the ZT-180...the problem that I am having is that the epad recognize the router hat I am using for my PC and laptop, but i am not able to connect via wifi to the internet either wireless or with a wired connection...any tips/suggestion :confused::confused::confused:
firstly,please turn on the wifi with correctly.then connect the wifi.
if it still not work,please change for the other place to try.
if it is not connect,the tablet pc maybe broken.
what version of the os are you using. i know that with zt-180 version 1 people can connect with build 1024 or greater. i'm having trouble connecting with android 2.2 builds to wifi.
