hi there, not sure what went wrong -
i wanted to install the latest firmware for the a8 and i did the reset. then i wasn't sure whether i should have the downloaded file on the internal sd or external an was having problems communicating with the pad and any of my computers. I finally put the file on a 4g external and slid that in hoping to transfer to the mount/...
anyways, when i went to look for the sd card to transfer it told me that the card was not mounted. i can't tell where along the way i did something wrong and have searched but can't tell what i should do to fix it.
also i've gone to the market looking for z4root and the search turns up empty, is it no longer available?
thanks for any help
thanks for any help
