Help!!! Wireless Keyboard mouse combo Woes
SupahDroid
15
My Microsoft Wireless Desktop 3000 Wont work on the tablet when You plug the USB Wireless receiver in The mouse only works and just the media button on the keyboard
i check the logcat said something about Device has more axis then frame work supports
:confused: How do i fix or what do i do?
Power the mouse off and see if you can get the keyboard to work. It might just be the mouse.
Microsoft keyboards are known to require way more drivers than most.
A cheap bluetooth travel mouse might allow the keyboard to work rvr if the microsoft mouse has too many axces.
Just a guess.
Same problem here, except its Logitech.
But both my bluetooth keyboard and mouse work great.
I guess the lesson is: if it has a usb dongle, you don't want it.
