HELP!!!!!! with Coby Kyros MID7012
Jermani
Hello everyone,
Im sorry if this is not the correct place to post this, anyways um I want to know why certain apps are not compatible with my device like for example My device shows me that the Dophin Browser HD is not compatible on the android market but in the Getjar Market it downloads just fine. Also I want to stream movies and shows on it as well but it seems that app in google play (Crackle) is not compatible, are there any other alternatives?
The market you might have is one for DONUT and outdated (1.5+)
The googleservicesframework is very outdated and simply doesn't know that much about the compatibility of your device so it
thinks everything doesn't work...even though it damned well does.
Try to update the market to froyo 2.2.11 or find my guide on how to get google play on it <-- Everything works with Play or Market 3.4.4 and froyo 2.2.11.
The market relies on your build.prop to gather system information to check compatibility.
There are many tips on editing this file BUT at your own risk. I have bootlooped my tab editing this for device trickery...so I advise not to.
