jerryferreira
- Jun 15, 2013
- 31
- 1
I'll try to make this short.
I rooted my MID9740 a couple of months ago. All went fine. Installed many apps from Google Play.
Some apps that I wanted wouldn't show up in Google Play because Google Play said they're incompatible with my device, but I sideloaded some of them and they worked ok.
Some I couldn't sideload so I wanted to change settings for my device.
I read this thread: http://www.androidtablets.net/forum...et-s-settle-google-play-compatible-issue.html
I went to replace the framework-res.apk with an edited one.
I deleted the file framework-res.apk from \system\framework
When I tried to put the edited framework-res.apk, the system starting going haywire. All apps were crashing, even my file manager.
I had to reboot.
Now all I get is when I turn on the tablet is the Coby logo. The screen comes on, but is totally blank.
I've tried to get into recovery mode, but it's just the same as turning it on, so I can't even get it to factory default.
What can I do (besides using it as a paperweight)?
I had to reboot.
