DankHemingway
- Aug 6, 2011
- 13
- 0
Hello I have had a Kyros 7022 for about 6 few months now and decided it was time to upgrade to ICS. I had previously successfully rooted the tablet and CWM was working great.
I tried to upgrade the 7022 from its stock ROM (Froyo or Gingerbread, don’t remember) to ICS. However while I was in CWM I managed to screw up the tablet. (I can be more specific if necessary)
Now, the only way I can turn off the tablet on or off is by hard reset. If I perform a hard reset it goes immediately into “fastboot mode”.
I can use the ”fastboot flash recovery recoverystock.img” command to get the tableto reboot into Android system recovery <3e> (Android System Recovery Utility) but this it where I get stuck.
I have downloaded what I thought was the stock recovery image for the Coby Kyros 7022. In fact I have downloaded many images and none of them will install without getting the “Signature verification failed…Installation aborted”.
Any help in assessing my problem would really be appreciated. Thank you in advance.
FYI...I have two S2 i777’s, an Acer A100 and A500 tablet. I have rooted all the devices and am running different custom ROMs on all of them. I say this only to say I have some experience rooting and installing ROMs. However, this 7022 has me stumped. I assure you it is not from a lack of reading forums or trying. I am just really frustrated and confused.
