GreenCounsel
- May 26, 2011
- 3
- 0
I am new to tablet PC and Android. I recently purchased SAWEE10 with the following:
Android Ver.
2.2 V2.1:3925
Kernal Version.
2.6.32.9
Infotm-sqa@infotm-sqa-desktop #82
Build Number
FRF95B
I have been trying to root the device, and I keep running into "USB Debug" mode required but "Development" options does not show up under "Applications". How do I turn on USB Debug if it is not on the tablet?
I would also like to move installed applications to SD Card, but when I go into the screen, the option to move to SD Card is grayed out and I can not move anything.
Lastly, I would like to know whether it is worth the trouble, trying to upgrade to Android 2.3 or 3.0, or if it is possible to upgrade to higher version with SAWEE10.
Thank you for your help.
GC
Android Ver.
2.2 V2.1:3925
Kernal Version.
2.6.32.9
Build Number
FRF95B
GC
