When I got my Kyros I only had a 2g card to put in it. Now I realize I need more memory. As a newbie tothe Android system, I have a couple of questions:
1. When I try to download apps (i.e. from the Amazon store) I frequently get a "not enough memory" notice even though in my settings it indicates Total space 1.83 GB and space available 1.39GB. Am I not putting the apps on my card? How can I find out? How can I be sure to save to SD card?
2. If I get a card with more memory, can I put the data from the 2G card into the new one? Can I simply put the 2G card into my PC, pull out the data onto my desktop and then trtansfer it to my new card?
I rerally like the Kyros and want it to work for me but I keep running into issues that keep the unit from becoming a good one. BTW I did root it.
Thank you!
Thank you!
