Hi all, my a2109 won't boot without plugging in charger first,at which point it boots into recovery first ,then I have to select reboot system.I'm on stock ROM ,unlocked boot loader,cwm installed and rooted.I have tried wiping all caches wipe data and even going back to stock recovery.also when I press power ,the volume slider appears and goes up a notch,which also stops me from shutting down as the shutdown menu does not appear,can anyone help?
Also I have just noticed the volume + button does the same as power button
