Get a file manager, Astro works. Go to \mnt (mnt is short for mount).
The on board memory is sdcard, the sd card is external_sd, and if have you something in the usb port it will be usb_storage.
So the paths are:
\mnt\sdcard
\mnt\external_sd
\mnt\usb_storage
Apps go on the internal memory, aka sdcard. There isn't a partition, so the only limit is your on board 14.4GB of memory.
The system memory area will see both drives, so you can always see how much you are using.
