home key not working pls help!!!
stadust
I'm having problems with my galaxy tab. I just bought my tab last week and i installed apps (angry birds 1,2,3 some live wallpapers kindle flash player update and aintivirus). and after some time when i leave my tab on standby, my tab will not open on soft press...it will open only if i long press it...then when i use my tab, the search key will not work, even my home key (setting key and back key working only). then some other weird things happening. my tab is hot even if im not using it, and my tab keeps on resetting!!
what is the cause of this? is it from the files i downloaded or from the device itself??? lps heeeelp! im tired or restoring it. i restored it 3 time already. help me pleaase....
I had a problem like this shortly after I bought my SGT 3G. A factory reset cleared it up.
