Thanks for your replay.Welcome to the forum
When you set the tablet up you used a registration to activate it which included a Google mail address and password. If you got locked out it will ask for those same items to get back in. If it isn't seeing what you are entering properly, (or possibly if you don't have a WiFi connection) you may need to resort to a factory reset. But I may be not understanding the problem.
Hi dhinvin, congratulations on your Teclast tablet and welcome to the forum. Nice of you to become a member of Android Tablets. To reset that tablet, try the following:
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
If that doesn't work, try Volume Down and Power buttons at the same time.
