I'm sure this question has been posed several times before, but perhaps due to the wording, it's difficult to find a thread that isn't referring to how long a battery lasts per charge.
Well, as it turns out, I'm downright impressed with my battery life on my Xoom. What I would like to know, rather, is the conventional procedure to making the battery last the longest over the life of the machine.
I understand that when being stored, batteries tend to be happiest at 1/3 charge. What about when the device is used every day? For example, should I wait until she drops to a certain percentage before plugging it in? Should I avoid running it down to 10% and lower? Is it better to use battery than to be plugged in? What I've done thus far is try to plug it in at 30%, which is once every two days under casual use. I also avoid keeping it plugged in at 100% for too long as that seems to have been harsh on my past laptops.
My ultimate question would be, how should we treat our batteries to keep them the healthiest over the life of the device?
Citing any references couldn't hurt.
And lastly, my apologies if this issue has been adressed. I'm still getting used to doing everything on a screen.
Motorola Xoom
Motorola Xoom
