I just bought a Huawei Ideos S7 and i know he has 8GB of internal memory, so instead of 8GB just shows 140MB somebody could help me to fix it ??? Please....... thanks!!!
Just do a search for link2sd and you should find the solution to your problem. Although it has an 8gig internal sd card the applications are actually stored in the 512meg internal memory.
My s7-104 has 140 meg rom. Go to settings, sd card and tablet storage. You should see 3 sectoins that says internal sd card, sd card and internal tablet storage. Internal storage should say 140 meg. Internal sd should say 8 gb.
Actually the 140 meg available for application storage is ram, a dedicated part of the 512 meg ram installed on the s7. What link2sd does is place a symbolic link in the system memory that allows the system to find the app where it expects it and is redirected to the actual files stored on a dedicated partition on the internal sd card. Works pretty well for me on my S7104.
