I need help!!!
JamieM
Im looking for a screen for my Scroll Essential II but they don't seem to supply them, i've found a digitizer for the Ployer Momo9 Enhanced III Edition which is visually identical to my current scroll digitizer including the connector but i'm unsure if it will fit or work, they are both 7 inch, both have curves on the corners and a camera hole in the same place, really need help with this, would be a shame to just throw my tablet away
Hi Jamie, welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
