Its going to be a problem unless Acer comes out with one, because the tablet charges at 12 volts, which is normal for Acer but the connector is pretty unusual.
Hi all if you have the acer A700 dont go buying expensive car chargers, I use the same charger that fits my HTC Wildfire and the desire will work too happy days
Icebike said:It will fit but it won't charge.
The tablet requires 12 volts. The wildfire charger only puts out 5.
Learn to read what the numbers printed on the charger mean.
Sent from my HTC One X using Tapatalk 2
Ah Icebike, still spreading the goodwill...
Sent from my Galaxy Note 10.1
Icebike said:Always willing to help out.
After all, people who get in the habit of plugging things in just because the plugs fit will make a costly mistake someday and ruin a perfectly good piece of equipment, or end a perfectly good life.
Ok, I'll give you that, tough love and all.
Anyone using a good car charger for Iconia A700? Does the A500 car charger compatible with the A700?
