Infotmic based Tablet GPS does not work.....help?
maghse
I have a Infotmic 10.2 tablet and the GPS is not working.... maps shows my location as Shanghi China.... can't seem to update the location nor does the GPS work... any ideas would be greatly appreciated...:(
Hi!
I have same problem. I found out that, GPS module start searching satelites. Level are way lower that it can use (about 10 of SNR green is 30 SNR ).
Sometimes found signals, but they are very weak. Is there some software solution of that problem?
I have issue with Wifi interface too, beacuse under preasure it disaled itself.
Have anyone some solution?
Andrew
