Dear fellow forum:
I have a tablet PC you buy on Amazon.
Irobot, MID, APAD 7 "firmware 1.6, android. Evaluate the connection via WiFi and it was good, then wired Ethernet LAN and it worked fine. THE problem or question was to install a USB Movistar Venezuela.
It is not how. Since the pc usually has a program to install. In case of Android, it happens. In fact, when I give the flash drive icon tells me empty folder., but tested on a PC and it works.
As I do to connect? He has a 3G icon and there I asked the following:
Name ----
Phone numbres ---
device (huawey e1750)
APN ----
USEr
Password:
I placed the tablet parameters and says he is connecting and the latter is the word off. what is the procedure or tutorial to connect my tablet 3g.
Help, please
PS: I bought the e756 huawey modem is they do in Venezuela.
Name ----
Phone numbres ---
APN ----
USEr
Password:
Help, please
