Is it bricked??? Help!
tornadotumble
28
I was installing the ClockwordMod and I got through the whole process and to the screen that has reboot system now, install zip from sdcard, etc. When I click on the install zip from sdcard, it moves back up the list to the reboot system now. However, I can't do anything, it won't even turn off. What do I do????
UPDATE: Ok, I got it to go off by pressing the menu button. I went back to the Clockworkmod Recovery screen to install zip from sdcard and it still won't let me. When I move down to it, it jumps right back up to "reboot system now". It will not let me choose any other option in that list either. Is there a way to fix this so I can install zip on sdcard?
Just got it! I was pushing the wrong button to select what I needed (duh!). Now all I need to do is install Honeycomb and I'll be good to go. I think I will wait a couple of days before I attempt that:).
