Launcher Pro Problem - Unable to Add Shortcuts
garygallardo
Hi I just bought a new Nook color. I am trying to add shortcuts on launcher pro but everytime I press shortcuts it just closes on me. Any advice is highly appreciated.
Gary
Launcher Pro bricked my KLU 8025, the only way I could get it to reboot was to remove and reformat the TF card, with it in the tablet would not boot after I installed it, I was lucky this time.
I do a long press on my homescreen, and then I press shortcuts. Same thing with the dock, I cannot add programs.
Then it just return to my homescreen. I am able to add widgets and launcherpro widgets.
I finally figured it out. You just have to go to where the apps are and and do a long press and when you go to the homescreen just drop it. Thanks all.
