Le pan will not snyc with facebook PLEASE HELP.
Yes it is wifi only. When you go to sync it will show Facebook but when you press on it just blinks and does nothing. I wanted to have it cus I can make wifi calls and wanted all my contacts like on my phone. Hopes this helps. and yes I did log in befor
Facebook most likely is associated with a differant email such as yahoo if so sybc that one
Sent from my TC970 (Wi-Fi) using Android Tablet Forum
Mine works OK with Facebook app and using a browser, so it is possible.
Has anyone tried to sync with Facebook are is it just me trying?
To clarify your issue, you are trying to sync your Facebook contacts with other contacts right? You are able to log on to Facebook through the web or the app? I can easily log on to facebook but I have not tried to sync my Contact list.
I can Login with the app fine just if i try to sync with contacts it want do it. Is the a setting I need to change maybe?
