location and bluetooth issues for mid a10 allwinner
breslever
i have got the ployer momo 3 tablet
i have purchased it from mcbub.com
McBub: Low-Priced Ployer MOMO3, USD 99.99, 7 inch Ployer MOMO3 Android 4.0 ICS Tablet PC AllWinner A10 1.2Ghz Capacitive Touch Screen Camera WiFI HDMI (CN110466)
i have a problem with the "location"
the device is not able to get the "wifi location"
is there any fix for this issue ?
and another question the android 4.0 is support the USB On The Go (OTG)
it work very good with my DISK ON KEY and also with my WIRELESS MOUSE DONGLE
is it possible that the OTG will suport a BLUETOOTH USB DONGLE
if it will then it will be possible to use BT GPS or BT STEREO HEADPHONES to here music
can some one tell me if its possible ?
Try loading a b/tooth app & see if it will work. If you can use b/tooth kbd it should do.
