Mach Speed Trio Stealth Pro Android 4.0.1 has crashed. Need Help !!!
wc025716
Mach Speed Trio Stealth Pro - I downloaded the "Google play store" app already. it's successful. But when I downloaded "checkpoints" app, I opened it. It will pop up the message "Unfortunately, checkpoints has stopped." I can not open it anyway. Is there any way to help me to solve that problem. 100000000 x Thanks!:p
Welcome to the forum,
Looking at that app it says it isn't compatible with my tablet, but is with my phone. It's very possible it was not intended for tablets. If you log into the WEB site and search for that app does it say it is, or not?
Hi wc, congratulations on your new tablet and welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you get that app working if possible. Good luck!
