Market problems
nymeria
Please help...
I have a problem downloading anything from the market... anything i try to install says "your application will be installed" but when i view it in my apps, it just says download unsuccessful, for no apparent reason. It never did this, usually the virus package viewed it and installed the app... please help
Sent from my IDEOS S7 Slim using Android Tablet Forum
Troubleshooting Android market app problems.
You probably need to clear the cache on the market app and possibly the data. those are covered in the link above.
If your anti-virus is intercepting apps before installation a setting in that may also be the issue. if the above tips don't help try turning off the anti-virus and installing a known good app (one you have used before).
I have a slight different of problem. When downloaded from market and install it will say cabt install in internal or sd card. What is the prob ya?
Rooted with soc and using link2sd. Ideos s7 104 no internal memory. Sd card 16gb. 1gb for second partition. Thanks guys
Not all apps though. The one for example that cant is tank recon 3d
