Micro SD card too small for SYNETLP-DS---fell in, won't come out
mcdelrod
I put what i thought was the correct micro SD card into the slot of my SYNETLP7-DS and it just fell right in because it was too small for the port! It rattled around for a while as i shook it. Then it stopped rattling and it must be stuck somewhere in the machine. Anyone have any ideas? Will the machine die? What size card does this take? Any ideas will be greatly appereciated!:confused:
To my knowledge, there is only one size of micro SD card. Unless that tablet calls for a full size SD card, I suspect you have the right card. You simply put it in next to the slot rather than into the slot. This has happened to a lot of people here. Apparently the space next to the slot is much larger than it should be.
