MID Freelander Pd10 Tablet wifi connection problems....
ronald_durst
I have a mid freelander pd10. I bought it specifically for use as a gps and media player in my truck. It has worked fine for quite a while not. I brought it inside to download some apps but i had trouble getting into the play store. I noticed that it is connecting to my router but not getting internet. Usually the indicator will light up blue when its connected. I did a reset of the system...but nothing. I reset my router and disabled the security and still wont connect to the internet.
I dont have theses problems with any other device in my house.
Model number is a777-c-MID-general
Android 4.0.3
Any help would be appreciated. Thanks.
