MID7035 CWM problem
jhax78
Hello peeps iam new here and would like some help if possible
device: Mid7035
i sucsefully used builder clockworkmod to build myself a cwm recovery image
now the only problem i have is some mount points can't be found resulting in errors
CWM log file
Code:
Starting recovery on Fri Jul 26 10:16:51 2013
can't open /dev/tty0: No such file or directory
framebuffer: fd 3 (800 x 480)
ClockworkMod Recovery v6.0.3.4
recovery filesystem table
  0 /tmp ramdisk (null) (null) 0
  1 /boot mtd boot (null) 0
  2 /cache yaffs2 cache (null) 0
  3 /data yaffs2 userdata (null) 0
  4 /misc mtd misc (null) 0
  5 /recovery mtd recovery (null) 0
  6 /sdcard vfat /dev/block/mmcblk0p1 /dev/block/mmcblk0 0
  7 /nand vfat /dev/block/ndda1 (null) 0
  8 /system yaffs2 system (null) 0
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
W:Unable to get recovery.fstab info for /sd-ext during fstab generation!
W:Unable to get recovery.fstab info for /external_sd during fstab generation!
I:Completed outputting fstab.
I:Processing arguments.
E:Can't find misc
E:failed to find "cache" partition to mount at "/cache"
E:Can't mount /cache/recovery/command
E:Can't find misc
I:Checking arguments.
Warning: No file_contexts
I:device_recovery_start()
Command: "/sbin/recovery"
ro.boot.serialno=0000130122211729126F
ro.boot.wifimac=
ro.boot.btaddr=00016C11B01E
ro.boot.memtype=2
ro.serialno=0000130122211729126F
ro.bootmode=unknown
ro.baseband=unknown
ro.bootloader=unknown
ro.hardware=m805_892x
ro.revision=8194
ro.emmc=0
ro.boot.emmc=0
ro.factorytest=0
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=1
persist.sys.usb.config=adb
ro.build.id=JDQ39E
ro.build.display.id=cm_m805_892x-userdebug 4.2.2 JDQ39E eng.hudson.20130726.005010 test-keys
ro.build.version.incremental=eng.hudson.20130726.005010
ro.build.version.sdk=17
ro.build.version.codename=REL
ro.build.version.release=4.2.2
ro.build.date=Fri Jul 26 00:50:45 PDT 2013
ro.build.date.utc=0
ro.build.type=userdebug
ro.build.user=hudson
ro.build.host=koushik-lion
ro.build.tags=test-keys
ro.product.model=m805_892x
ro.product.brand=coby
ro.product.name=cm_m805_892x
ro.product.device=m805_892x
ro.product.board=m805_892x
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=coby
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=unknown
ro.build.product=m805_892x
ro.build.description=cm_m805_892x-userdebug 4.2.2 JDQ39E eng.hudson.20130726.005010 test-keys
ro.build.fingerprint=coby/cm_m805_892x/m805_892x:4.2.2/JDQ39E/eng.hudson.20130726.005010:userdebug/test-keys
ro.build.characteristics=default
ro.cm.device=m805_892x
ro.rommanager.developerid=cyanogenmod
keyguard.no_require_sim=true
ro.url.legal=removed link
ro.url.legal.android_privacy=removed link
ro.com.google.clientidbase=android-google
ro.com.android.wifi-watchlist=GoogleGuest
ro.setupwizard.enterprise_mode=1
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=false
ro.cm.version=10.1-20130726-UNOFFICIAL-m805_892x
ro.modversion=10.1-20130726-UNOFFICIAL-m805_892x
ro.config.ringtone=Orion.ogg
ro.config.notification_sound=Argon.ogg
ro.config.alarm_alert=Hassium.ogg
ro.carrier=unknown
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.adb.qemud=1
dalvik.vm.lockprof.threshold=500
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
init.svc.ueventd=running
init.svc.recovery=running
I:Checking for extendedcommand...
I:Skipping execution of extendedcommand, file not found...
E:failed to find "userdata" partition to mount at "/data"
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
E:Can't find misc
W:Can't unlink /cache/recovery/command
Error mounting /cache!
E:failed to find "system" partition to mount at "/system"
Error mounting /system!
E:Can't find misc
E:Can't find misc
my devices recovery.fstab also used to build the recovery
Code:
# mount point    fstype        device            [device2]
/boot            mtd            boot
/cache      yaffs2       cache
/misc        mtd            misc
please if anyone could help me resolve this or put me in the right direction i would be greatfull
if any extra info files or anything is needed please say so and iĺl provide them
The builder isn't very good, or I guess I should say it's very limited, only some devices are supported, the best method to get a recovery is to build it from source, modify the source to the particular device you want the recovery to run on then compile the recovery.
I don't have a Mid7035 but I pretty sure that recovery.fstab is wrong, doesn't look right, do you have your original stock recovery?
OK I downloaded Folken's 7035 dump, and as I thought your recovery.fstab is wrong, below is from Folken's 7035 dump.
Code:
# partition		mount_point		fs_type			device
sdcard			/sdcard			vfat			/dev/block/mmcblk0p1
system			/system			ubifs			/dev/ubi0_0
userdata		/data			ubifs			/dev/ubi1_0
cache			/cache			ubifs			/dev/ubi2_0
misc			/misc			raw				misc
kernel			/boot			mtd				boot
recovery		/recovery		mtd				recovery
hello vampirefo
i can't thank you enough for helping me with this
wierd thing is the recovery.fstab i used came fom my own stock recovery.img if that makes sense
i have uploaded the stock recovery to stockrecovery.rar if you want to check it out
i am breaking my head on this one please if i need to upload dump or do anything just say so and ill do it
again i thank you for helping me out
hello vampirefo
OK that is weird the recovery you uploaded is for a telechips tablet, The original Coby 7035 is a VI Micro.
ok that's wierd then it says coby mid7035 kyros on the back
i have a strong feeling it's just some rebranded thing then
i bought it from here Coby Kyros MID7035-4 Internet tablet 17,78 cm (7) zwart 1 GHz (Cortex 8) Android 4.0 Tablet-pc in de Conrad online shop
any idea how to solve this?
if i open a terminal on the tablet and use busybox df -h
the output i get is
Code:
[/COLOR]Filesystem                Size      Used Available Use% Mounted on
tmpfs                         188.9M     32.0K    188.8M   0% /dev
tmpfs                         188.9M         0      188.9M   0% /mnt/asec
tmpfs                         188.9M         0      188.9M   0% /mnt/obb
/dev/block/mtdblock2    380.0M    247.3M    132.7M  65% /system
/dev/block/mtdblock5       1.5G     762.5M    773.5M  50% /data
/dev/block/mtdblock4    512.0M      9.3M    502.7M   2% /cache
/dev/block/vold/179:1       1.9G    132.9M      1.8G   7% /mnt/ext_sd
/dev/block/vold/240:1       1.4G      1.1G    285.3M  79% /mnt/sdcard
[COLOR=#333333]
busybox df -h is useful for determining how full your partitions are, but doesn't help in your case.
just use mount command to see how the partitions are mounted.
Either way the recovery is going to have to be built manually, the builder isn't going to be able to build a working recovery for your device.
Vampirefo thank you very much for the help so far
iam happy i did read all those threads about compiling one and already have the tools installed in ubuntu to do so
now i only have to wait till the kids go to bed so i can do my thing
again thank you very much for this
Argh im pulling my hairs now lol
so i compiled a recovery from the latest CWM source and behold the same error sigh...
btw this is what the mount command from adb shell tells me
Code:
rootfs / rootfs ro,relatime 0 0tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/sdcard/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mtdblock2 /system yaffs2 ro,relatime 0 0
/dev/block/mtdblock5 /data yaffs2 rw,nosuid,nodev,relatime 0 0
/dev/block/mtdblock4 /cache yaffs2 rw,nosuid,nodev,relatime 0 0
/sys/kernel/debug /sys/kernel/debug debugfs rw,relatime 0 0
/dev/block/vold/179:1 /mnt/ext_sd vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/240:1 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
/dev/block/vold/240:1 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
ok after some digging around i decided to put the coby aside (for now ofc ) and have a look at this broken TOMTEC exelent 7" i have here too
i thought lets dump the TOM TEC and check it's recovery.img out
now i had a problem the touchscreen, charging part and the Wifi card is dead
after some brainstorming i desoldered the Wifi card and soldered a USB hub in it's place
and removed the battery and used a old pc PSU to power the hub and tablet
after that i plugged in a mouse and keyboard and booted it up YESSS!! it works
both devices work like a charm and i have still the mini usb connector to use for ADB tool and usb storage
i found out it almost uses the same hardware except the CPU runs @ 1.2Ghz ( Coby MID7030 runs @ 1.0Ghz)
Ram on the tomtec = 1Gb (Coby MID7035 = 512Mb) + the Tom Tec has hdmi
it uses the same recovery.fstab and clockwork mod works
i can make backups and such
now i am trying to compile some drivers for a usb Wifi dongle i have so i can plug it in the hub and have Wifi again
the ultimate goal now is to get a old hdmi monitor and buy a touch screen kit from ebay and built the TomTec hardware inside it
so it will become a big tablet for my kids to play with
ill try to make some pictures to show it but after i have cleaned the wires and such up a bit on this Franken Tablet
Greets Jhax78
