MID8125 Firmware HELP!
bluedory
I have royally skrewed up my MID8125 for being a noob :(
My initial attempt was to reload the Original Firmware due to a sleep mode issue. I used this post:
http://www.androidtablets.net/forum/coby-generation-2/31428-here-firmware-8125-a.html
I
unknowingly changed the start logo to "MediaCom" instad of "Coby"! The firmware was also in Italian and changed other small issues such as camera being upside down!
Is there any way to revert back to the Original Coby logo and firmware? If someone can send me their *.rom and *.img i would greatly appreciate it.
Also, I used FWDN software using the provided lk.rom and m801_mtds.img which is probably the ones that changed my Coby Logo.
I would greatly appreciate anyone's help!
Thank you.
I
Thank you.
I have the same problem. And I would greatly appreciate anyone's help too!
Once you use FWDN there is nothing that can be done to fix your problems, this firmware shouldn't be used on an 8125.
This firmware works just fine with the Coby Kyros Mid8125 Tcc8803 Model I have. I have Clockwork recovery installed, it's fully rooted and all the Google apps installed. Just follow the link to the site above "firmware for 8125" click Supporto e video and choose "Sistema operativo Tablet 800_8125" The system is Italian but is easily changed to English.:cool: You can change it permanently to any language or time zone by altering the system build prop file. Or check this out it's an update zip rom kit I made.http://www.androidtablets.net/forum/coby-generation-2/59241-mid8125-update-zip-available.html
