bryancartwright
- Jul 16, 2013
- 9
- 0
Welcome to day 4 of my Kyrosall headache. I found my MID9740 on Craigslist for $15.00. I am fairly proficient with android and laughed when the seller claimed the tablet was bricked. I repair bricks more often than a mason... Until the Coby Kyros...
Now, 4 days later I am ready to retire my SuperUser cape and sit at the noob table.
I now submit my recovery.log to this forum and pray that the Gods like Vampirefo and Traveler 1701 may take pity.
*Issue- Obviously I have no dump. The tab was stuck on Coby logo, and has never booted past that. I was able to replace stock recovery with cwm and get adb up and running. The partitions on this thing seem wrong to me. I can only mount when external sdcard is in. I am unable to mount my /data file, I can format it with Clockwork but it takes about 5 minutes. Here is the output of recovery.log.
and mount
Please let me know what else you may need.
Starting recovery on Fri Jan 1 03:56:59 2010
framebuffer: fd 4 (1024 x 768)
CWM-based Recovery v6.0.2.8 9740 by Vampirefo
recovery filesystem table
0 /tmp ramdisk (null) (null) 0
1 /boot emmc /dev/block/nandc (null) 0
2 /system ext4 /dev/block/nandd (null) 0
3 /data ext4 /dev/block/nande (null) 0
4 /misc emmc /dev/block/nandf (null) 0
5 /recovery emmc /dev/block/nandg (null) 0
6 /cache ext4 /dev/block/nandh (null) 0
7 /sdcard vfat /dev/block/mmcblk0p1 /dev/block/nandk 0
W:Unable to get recovery.fstab info for /datadata during fstab generation!
W:Unable to get recovery.fstab info for /emmc during fstab generation!
W:Unable to get recovery.fstab info for /sd-ext during fstab generation!
I:Completed outputting fstab.
Irocessing arguments.
I:Checking arguments.
I:device_recovery_start()
Command: "/sbin/recovery"
ro.serialno=
ro.bootmode=unknown
ro.baseband=unknown
ro.bootloader=unknown
ro.hardware=sun4i
ro.revision=0
ro.emmc=0
ro.boot.emmc=0
ro.factorytest=0
ro.secure=0
ro.allow.mock.location=1
ro.debuggable=1
persist.sys.usb.config=adb
ro.build.id=JZO54K
ro.build.display.id=full_9740-eng 4.1.2 JZO54K eng.vampirefo.20130521.020547 test-keys
ro.build.version.incremental=eng.vampirefo.20130521.020547
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Tue May 21 02:06:30 EDT 2013
ro.build.date.utc=0
ro.build.type=eng
ro.build.user=vampirefo
ro.build.host=vampirefo-GA-MA78GM-US2H
ro.build.tags=test-keys
ro.product.model=Full Android on Emulator
ro.product.brand=Android
ro.product.name=full_9740
ro.product.device=9740
ro.product.board=9740
ro.product.cpu.abi=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=unknown
ro.build.product=9740
ro.build.description=full_9740-eng 4.1.2 JZO54K eng.vampirefo.20130521.020547 test-keys
ro.build.fingerprint=Android/full_9740/9740:4.1.2/JZO54K/eng.vampirefo.20130521.020547:eng/test-keys
ro.build.characteristics=default
ro.cm.device=9740
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.carrier=unknown
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.adb.qemud=1
ro.kernel.android.checkjni=1
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
init.svc.ueventd=running
init.svc.recovery=running
service.adb.root=1
init.svc.adbd=running
ro.serialno=
ro.bootmode=unknown
ro.baseband=unknown
ro.hardware=sun4i
ro.revision=0
ro.emmc=0
ro.boot.emmc=0
ro.factorytest=0
ro.secure=0
ro.debuggable=1
ro.build.id=JZO54K
ro.build.date.utc=0
ro.build.type=eng
ro.wifi.channels=
ro.cm.device=9740
ro.carrier=unknown
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.adb.qemud=1
net.bt.name=Android
service.adb.root=1
I:Checking for extendedcommand...
I:Skipping execution of extendedcommand, file not found...
E:Can't open /cache/recovery/log
E:Can't open /cache/recovery/last_log
W:Can't unlink /cache/recovery/command
and mount
mount
rootfs on / type rootfs (rw)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,mode=755)
devpts on /dev/pts type devpts (rw,relatime,mode=600,ptmxmode=000)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
/dev/block/nandh on /cache type ext4 (ro,nodev,noatime,nodiratime,user_xattr,bar
rier=1,data=ordered)
