Need Help for Two Devices
CoRtEx
hello community
my english isnt the best but i try it as good as i can
(im so sorry if i open the thread in the wrong directory .. searched whole day on google and dont found the goal)
i have here 2 tablet devices (as a present from my parents .. both not much used and totally original (original firmware and so on))
both not working as they should do
both devices are the same
Empire Electronic (standing on the backside of device)
with Android - version. 2.2-20110529
-kernel version 2.6.32.9 zjd@dtlinuxserver #77
build number FRF85B
the modell number of devices are Disco 10
so here are the problems
first Device:
is running
but i had a problem with synchronization android.process.acore
it was a popup about an closed process
i disabled the synchronization with the activated googlemail account and stopped the processes
also the one from google play framework
after reboot i dont got the popup again and i have been happy for it
but now i want to get the device back to factory defaults
i searched hours again(im an android smartphone user .. so its not new for me)
but i dont found the option to do it..
the device told me that i would find it about privacy police (hope thats the right description)
but i cant find this in menu too
device 2
not much used and have been in the cupboard for a long time
yesterday it got recharged
today we tried to start it
the android symbol in mid and top left appears
than "Android_" is standing on the screen and much time later too
nothing happened further
via power and menu button i started the recovery of the device
but with the same result
so how can i fix it
i need a solution best without changing the firmware to any custom one or something
pls help and i will thank u for any help here
greetz cortex
device 1 is now working
i started the sytem recovery and kept the buttons hold dow
but the non booting device still wont work
