Need help in aPad identification for Rooting & Firmware Upgrade
adrian
Hi,
I recently bought a aPad & wanted to find its info so as to upgrade it. After using Android System Info, i got the following info. The details had got me confused:confused: as i couldn't determine what model it is from the posts already made in the forums. Please help me out in upgrading the device. :(
Can i load flash in this device ? also, i was unable to play videos properly nor hear them (MP3 files were coming up OK, but bit scratchy).
Regards & Thanks in advance.
Hi,
Thanks for pointing out the model & make of the device.
I had referred to the post below for rooting & flashing :
http://www.androidtablets.net/forum...touch-firmware-releases-via8505-7-tablet.html
Is this the one to refer to for flashing new ROM ? i also want to have market so that i can install apps & have root, so should i be using the below link's post for the ROM ?
http://www.androidtablets.net/forum...-1-9_88-rooted-v0-3-working-market-flash.html
Also, i am unable to connect properly using Wi-Fi. Its connects occasionally & i can't access my PC from from the tablet or vice versa. I am using swiftp(tablet) & HFS(PC).
