Hi
I have a MID ANDROID tablet. Its 7 inch mod.
My initial problem is that I cant't switch it on, the power button is broken and the power switch on the mb has come loose totally.
Is there any other way to switch it on??
When I connect the charger the tablet pc starts to charge and shows the android battery charging icon mid screen for a few seconds then black screen.
I was told to connect the USB to my macbook and that should power it on but it doesn't, just charge sign again.
I really need to get this working ASAP and will only open and solder the button back on the mb when I know its working.
Please help me with this if you know how to power it on without using the button.
Thanks for reading.
Thanks for reading.
