need help to identify tablet and upgrade options
n5eea
I'm new to tablets. I purchased a used one unseen (maybe my mistake). When it boots it shows a Infotmic logo, then in lower right corner 0.6.1.5(559)
Tablet info under settings is:
Model SAWEE Pad
Firmware: 2.1-update1 V1.8:#2752
Kernel: 2.6.32.9
infotm-sqa@infotm-sqa-desktop#48
Build:
WWE10-eng2.1-update1 ERE27 eng-infotm-sqa.20101224.184001 Test keys
It has a port for a GPS, but no antenna
Ethernet jack, HDMI jack, (2) miniDS card ports (marked as TF Card), (2) USB ports, camera.
No BlueTooth that I can tell.
It does have wireless.
There info in the Settings for 3G, but doesn't respond to anything when pressed.
Can anyone tell me the manufacture or brand name of this unit?
Can it be upgraded to Android 2.3 or better? If so, how?
regular Android Market does appear to work.
There's nothing in the settings indicating built in Bluetooth, but if I try to put in a bluetooth device in a USB jack, it recognizes it, but won't connect.
Can this unit be tetherd to a cell phone? If so, what is the best application combo to use?
Can this be successfully rooted? If so, what is the process?
Hopefully someone here can answer most of my noobie questions. Thanks in advance.
I found a web site that has limited contact and support information.
Google Translate
Apparently it supports 2 32GB microSD cards in the slots marked TF Card.
[h=4]Outline[/h] IMAPx210 a high-performance ARM11 core-based multimedia applications processor. Its internal integrated 2D/3D graphics processing, video processing, audio processing, display processing and scaling, and other powerful hardware accelerator performance. HD 1080P video accelerator supports JPEG, MPEG4, H.263, H.264, VC1, RV8/9/10, DIVX4/5/6, XVID and ON2 VP6 decoding and supports up to SXGA resolution JPG, MPEG4, H .263, H.264 encoding. In addition IMAPx210 also integrates hardware 2D/3D graphics accelerator, to meet with the effects of man-machine interface and 3D gaming applications. IMAPx210 use TSMC 65nm low-power CMOS technology, CPU frequency up to 1Ghz. IMAPx210 can be applied to high-end handheld multimedia devices, mobile Internet devices, netbooks, e-books and other consumer electronics.
[h=4]Features:[/h]
1) ARM11 core, clocked at up to 1GHz
2) Support multi-format full HD decoding (1080P), support for JPEG, MPEG4, H.263, H.264, VC1, RV8/9/10, DIVX4/5/6, XVID and ON2 VP6 and other formats
3) to SXGA resolution JPG, MPEG4, H.263, H.264 encoding
4) support for 2D/3D acceleration, support OPENVG1.0 and OPENGL ES 1.1/2.0 Interface
5) support for DDR2 and MDDR, up to 2GB capacity
6) Support MMC / SDHC / SDIO / CF / PATA / IDE and other storage devices
7) Support USB2.0/USB OTG 2.0
