Need help using rom manager
Krazy302
I rooted my m701-r with z4root and now before I do anything else I want to make a backup of my current rom. I installed rom manager and am trying to use clockwork recovery in it, it askes what type of phone I am using which one do I select, as this m701-r is not listed???:confused::confused::confused:
you'll probably have to flash clockworkmod recovery manually. you will most likely have to look for a copy ported to your tablet/chipset, keeping in mind that recovery.img contains a kernel and some very basic system files (this is so it can boot far enough to run the recovery binary). so you can't just grab the recovery.img for, say, a telechips tablet, flash it on an infotmic tablet and expect it to boot into recovery.
I used adb to install clockwork recovery,rom manager is useless on our pads as far as I know
