Nextbook Power Cord
bbqbrisket
Sep 21, 2015
I have one of the newer Nextbook 11.6 tabs.
I'd like to purchase a separate power cord that uses a USB at the opposite end.
I cannot figure out the size of the power barrel it uses.
I purchased a 2.5 mm and found out that was too small.
Does anyone know what size it uses?
Contacted EFun but I'm sure you guessed it, they were absolutely useless.
thanks
Thanks for your response.
Mine came with a power pin on one end and DC power converter attached to the other. I would like to buy a separate DC converter that takes a USB.
Thank you for responding.
I have a very very hard time believing the power pin/barrel plug used is proprietary.
There are lots of other tablets that have proprietary attachments, Microsoft Surface Pro and most ASUS tablets among others
One of their newest tablets, the Surface 3, has a micro USB port and everyone who has used the proprietary connection wants it on the Surface 3 too.
Personally I think they should all go to a barrel connector. There would be far fewer bunged up charging ports.
