No sound with coby kyros 7048
trininikki
hi there i'm having a problem with my coby tablet.
there is no sound from the buit in speakers but when i use the headphones i hear fine.
i did a factory reset and still nothing.
please help.
Hi Trininikki. When headphones are inserted into the tablet it operates a switch that turns off the main speakers. This switch may have become stuck in the off position when the headphone plug is removed. Sometimes inserting and removing headphone plug may fix this problem. Also make sure the main speakers are not muted in settings. If this situation persists you may need to get it repaired at an authorised repair shop or returned to manufacturer. Good luck!
Thanks i'll give it a try
