I have a U30GT - H and have already flashed to Evo Prime 1.3. It was a bit of a bumpy ride as I ended up having to do a hardware reset after disassembling the unit. When I disassembled it I discovered a poor solder connection on the battery wires. It was getting intermittent power so when it shut down during the flashing process, it ended up bricked. All is fine now except for one problem, when I connect the USB cable to my PC, I don't get the option to mount the USB storage. I have tried reinstalling the drivers, but no luck. This is the same machine that I flashed it on, so I know it isn't a cable or hardware issue. I have tried the included cable and the one that came with my Samsung SG2.
Out of desperation, I tried the PDA net program and that works fine.
Any suggestions?
Any suggestions?
