no wifi after reinstalling firmware
someguyinPA
Been searching the net for 2 weeks now, and still no answer.
I have a Irulu AL 101 it was stuck on boot screen. I reinstalled the firmware downloaded from Irulu`s website. Installed fine except now no wifi, When i switch it on it says "turning on wifi" then wifi switch slides to off. I ran a logcat , i got an error code 154 failed to load driver.any ideas ?
logcat
D/WifiHW ( 154): insmod wifi driver...
D/WifiHW ( 154): faied to read proc/net/wireless
E/WifiHW ( 154): timeout, register netdevice wlan0 failed.
E/WifiStateMachine( 154): Failed to load driver!
logcat
Part of your logcat is missing the name of the wifi module, most likely the firmware you installed isn't correct for your wifi chip, contact the place you bought the tablet and ask for firmware for your device, explain the firmware you used doesn't match your wifi chip so no wifi you want correct firmware or replace your tablet.
that is the only firmware for the model tablet actually , here is the rest of my logcat
D/WifiHW ( 154): start to isnmod 8188eu.ko
E/BluetoothAdapter( 1526): this device does not have Bluetooth support
D/ViewRootImpl( 1492): pckname = org.jtb.alogcat
D/audio_hw_primary( 88): start_output_stream: card:0, port:0, rate:44100
W/InputManagerService( 154): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@412a9110 (uid=1000 pid=1526)
D/OpenGLRenderer( 1526): Flushing caches (mode 0)
D/dalvikvm( 1492): GC_CONCURRENT freed 3281K, 39% free 7413K/12039K, paused 1ms+4ms
D/OpenGLRenderer( 1526): Flushing caches (mode 1)
D/dalvikvm( 1492): GC_CONCURRENT freed 109K, 36% free 7745K/12039K, paused 2ms+5ms
D/dalvikvm( 1492): GC_CONCURRENT freed 254K, 35% free 7913K/12039K, paused 2ms+8ms
E/WifiStateMachine( 154): DriverFailedState
i saw on another forum during a google search there seems to be a recurring issue with irulu , once you reinstall with the firmware off the website wifi gets knocked out ?
It's trying to load 8188eu.ko, but unable to cause your wifi is different. Not much you can do, get a dump from someone who's wifi is working.
