Hello world, please help me.
I've been messing around with my 1-day-old nook color in order to make it into an adroid tablet. First i'll state my problem, then i'll give the details of everything i've done to the nook with as much detail as possible.
problem: upon boot up i get a cursive nook color screen which then proceeds to an "n" above that is grey, then a rainbow color flowing "color" below.
1. I used an autoroot on my SD card with the Cyanogenmod7 this morning. EVertything worked great, but the Cyanogenmod would only run with the SD card in the nook. if taken out the nook would revert back to barnes and noble normal mode. I decided i want to fully root because i couldn't get netflix to work.
2. i proceeded with the manual nooter 4.5.25 ... installed it through the 2gbClowork Recover 3.0.0.5. Then installed the Cyanogenmod7 through that. Upon reboot the nook color screen with the rainbow stayed up for a long time.
3. I used the factory restore instructions nook-complete-restore-1.0.1 using this dude's video . I was getting an error when trying to format the data - ERROR FORMATTING DATA. upon restart it went to the barnes and noble screen first, then to the nook color rainbow screen and stuck.
4. since then i've tried doing all sorts of formatting through the Clockwork recovery, clearing caches, delvik cashes, system, boot, etc. the restoring again. tryed butting cyanogen on again. and tried using AUTOROOTER2.25.
same result every time.
Please help - i need a way to zap the stupid rainbow nook color thing out of the memory of the nook so that i can proceed to load other ROM's or go to the original Barnes and Noble mode.
Thank you
Matvey
Thank you
Matvey
