I have found many threads here and elsewhere re the Nook overheating but they are all charger related. Mine has been off the charger for almost 20 hours. I was using the nook with about 45% battery left and it suddenly shut down. I figured out how to do a hard restart and got it back on. It was off for about half an hour. At that point, my battery app said it was at 20% and battery temp was 91'F.
It is not rooted. Could this be a rogue app causing it to overheat and drain battery that fast? As I was trying to figure out the issue, I note that the cooling vent is on the back. I have a B&N case that it stays in. There is a small depression in the case where the cooling vent is, but if it needs air circulation to keep cool, that wouldn't help.
Had the Nook about 3 weeks and first issue. I don notice some days the battery drain is much higher than others, but my usage is fairly consistent.
Any thoughts or ideas?
TIA
Darryl
TIA
Darryl
