iiDiabolusZz
- Nov 9, 2012
- 441
- 113
Just to let you no that some of the Onda firmware is bundled within a zip file, you need to have a file similar to this g12refM806A2SPI.zip the numbers will be different depending on tablet model, this is the firmware file that needs to be left on sd, you may also have a file called patch.zip this is all the chinese apps so unless you want them, bin it.
