Onda V972 Screen Problem
MUG3NHC
Hi all,
Im new to the forum. I recently purchased an Onda v972 and after examining it a bit i noticed that on the edge of the right side(black frame) screen is a little bit loose, you can push it down 1 or 2 milimiters. The left side is alright.
So, do you know of any situations like that or if thats fixable or do you think i should ask for replecement?
Thanks for reading and i hope i will receive some advice.
Cheers!
