Onda v972 the problem of sensor resolution (for all tablet pc).
Ultraviolet
7
Onda v972 has a pitch of 4 pixels on the touch screen (You can see it if set "Show Touches" in "Developer Options" menu). This disrupts the smooth interface and smooth scrolling. It's probably a driver problem, since the tablet Ainol Novo9 Spark sensor resolution is 1px. Who can help set a pitch of resolution of touch screen by 1 pixel, if possible.
For example Onda Vi40 has a touchscreen resolution of 1 pixel stitch. The Samsung have an application TouchScreenTune for fine-tune settings of Samsung Galaxy Tab 10.1 touchscreen. This program has a parameter "Minimum movement amount" that has a recommended value of "0", but for the tablet Onda v972 this value is 4px. It should also be noted that when the speed of movement on the touch screen, the value of missing pixels increases. It is enough to cause a significant decrease in speed of the interface and control in games, I'm sure there are ways to correct this parameter. Who know how it do?)
