Pandigital Firmware problem
johnfin
I downloaded the US and CA versions of the firmware (exe loaders) from pandigital and I cant get them to work properly. It gives me a Novel USB error message on the PC. I tried different PC's and I get the same message. What is the problem?
I had a similar error, except it said ".net" error instead of USB error. I updated .net to 3.5 (you have to go manually into control panel and uninstall older versions of .net using the add/remove program) and was able to download the android tablet firmware update. It was slow and annoying, but I have had fun playing with it since. I had to download the YouTube-v13.apk and authorize apps from outside Slide to get YouTube. Hope this helps
