Paranoid Android 4.0 Is Built from Scratch with KitKat Base
Spider
15,781
1,812
499822c2294907631ad6d2be65f5c3eb
by Shawn Ingram on March 3, 2014 10:07 pm
The team behind Paranoid Android recently announced that it was killing the Halo multitasking system, but it turns out the team had larger plans for Paranoid Android that will change just about everything.
With the release of a KitKat-based ROM Paranoid Android will hit version 4.0, but first the team decided to rebuild the entire ROM from scratch. The new PA won’t port over everything from version 3.99, instead the team wanted to focus on making the next version more like stock Android. Almost everything in the ROM is being redesigned to fit the team’s vision of what makes a great ROM based on stock Android.
The new direction for Paranoid Android means there will be less “kanging” in PA 4.0. The team won’t borrow features from other ROMs, and will instead focus on making its own features in its “Googly” way that makes them simple to use and easy to modify. That doesn’t mean there will be no borrowing of features — the team will look into incorporating features the community wants that match its standards, but nothing is guaranteed.
The ultimate goal of PA 4.0 it to attract more people to the ROM, and not just the usual lot who are comfortable with command line operations.
One of those added features, Pie, will be updated to fit the same aesthetic of the Google Now Launcher that debuted on the Nexus 5. That means it will have easy access to Google Now with a swipe to the left-most homescreen. It also means new typography and smother animations. Of course, Pie will have its own features such as the ability to hide the navigation bar and status bar. The above video shows how Pie lets you use gestures instead of having the navigation bar on screen at all times.
As for the Halo multitasking feature, it will be replaced by a new feature called Hover that will be similar, but different enough to justify a new name.
Paranoid Android 4.0 is now available as a beta, though there’s no word on when exactly a final version will be ready.
