Please help...Craig 7" "CMP741e" lock-out
Lissa223
Purchased apprx month ago, for some reason it locked me out and is requireing a google account info to un-lock...but was never prompted to link it with google at set up? What to do?
The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.
http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
http://www.craigelectronics.com/firm...irmware4.0.rar
(install instructions: http://www.craigelectronics.com/firm...guide_741e.doc)
HOWEVER! Some CMP741 units will end up stuck on the green Android screen with this version!
If that happens, Craig has supplied a cleaner firmware in case that the first one fails,
http://www.craigelectronics.com/firm....0_cleaner.rar
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue.
The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again.
