Please help with ICS firmware update....
thibs
I have a Basic running HC 3.2 and tried to update firmware to 4.0.3. I followed the instructions and everything went normally except when it rebooted everything was the same. Still on the 3.2 OS. Then I tried again but this time I tried 4.0.1 update and then the same thing. Any help on this would be greatly appreciated. Thx in advance.
Well I don't know if I'm asking the wrong questions but I've been reading all I can find. The directions seem to be pretty simple so if I'm missing something I can't figure it out. Only thing I found was I should be formatting the microsd card as a FAT32 which I was from my mac. Only thing I can think is that my micro sd card is faulty. Anyway I'm pretty much a noob at this so any help would be appreciated, thx.
Why did you post this in the Novo7 section? You should ask about it in the Android 4.0 section.
Hi
We have written the detail update method in our section,you can check here
When you do the update, have you found the robot logo?
Hope we can help.
