Ployer Momo 11 Extreme or Pipo Max M1
jamesshamim
Hi,
I am interested in buying the Momo 11 extreme or the Pipo Max M1.. I would mainly use it in Uni or on the coach to football away games! Battery life and Wifi strengh are the most important factors for me.
Which would you recommend?
Thanks, James
Hi,
Thanks, James
Hi James
Both are excellent tablets, you can't miss with either. Both should last the coach journeys if you charge them up first, both have 3G dongle support and good wifi strength (we didn't notice they were particularly poor compared to others). Sometimes when manufacturers put fancy alluminium back casing on their tablets the wifi struggles to get through but these are ok. If you want me to be really picky the I made it further across the car park with the Pipo Max M1 before the wifi cut out.
