printing help!
rachelisrad
I no longer have a PC and my printer is older and only connects via USB, is there a way to connect my Acer iconia a200 to my old canon with out having a PC?
Not sure. I have a Pixima printer but newer model, and I jsut use the Canon App to print via wifi directly from the phone, or to scan from scanner on it to the phone.
Heck you can get the 2600 series or what ever for liek 50.00 or less and it's an amazign printer.
worthy note you also do not need a pc on those models to copy directly on the printer, or use the storage card slots on it. THey have dual trays (front loaidng tray like a laser jet, and a rear load slot).
You been given one option. There is another.
Get a USB print server and connect your printer to your network via that. Then you can load compatible drivers and print via them. That is another option.
