PROBLEM ON Hyundai TABLET!!!!!HELP!!!! AS FAST AS YOU CAN
softprotop
Hi, I used your program " Unlockroot" on my device which is "Hyundai
YG A7 ART Android 4.0.3", after i install the root in my device I got
a problem which is after I full charge my device and disconect it
from the charger the battery finish within 2-3 minites or sometimes turn
off in a secound, After that I unrooted my device and still the same
problem. the mane problem is from the software.... I really would
like
your help as fast as you recive this mail.
Telechips 8923
You need to see if you can reset the battery statistics from recovery. Try doing this after a full night of charging so the battery can calibrate properly.
There is no problem in the battery when the Login was put on Recovery Mode work properly
